Floating ball on free surface validations
Old   November 10, 2008, 16:30
Default Floating ball on free surface validations
Bak_Flow
Dear Fluent Forum,
I am working with Fluent on a case for which I need to do some validation. The case is a transient air-water tank with a ball floating on the surface initially. The geometry is 2-D axi-symmetric, transient and the ball position is solved with a 6 dof solver which really collapses to 1 dof solver due to the symmetries.
The objective of the simulation is to determine the ball position as a function of time for various tank sizes and initial conditions. Initially the ball is floating on water: sg of the ball is about 0.85 but as the tank empties the hydrodynamic forces on the ball pull it below the water level and it seals in the bottom.
Does anybody know of some vaidation work which involves some or all of the physics:
free surface solution in a tank which is draining/presurized and/or floating ball validation in a tank.
Thanks in advance.............Bak_Flow
Validations? -- Heat X-fer -- Cyl in Xflow Glenn Main CFD Forum 1 March 5, 2013 04:06
Floating ball on free surface validations Bak_Flow Main CFD Forum 0 November 10, 2008 15:57
Gambit: Volume mesh starting from floating surface Peter FLUENT 0 July 31, 2007 13:26
free RANS code with free surface ability Lou jing Main CFD Forum 1 July 11, 2003 14:43
Flow field around a ball that doing free fall in a cube Nadomic Lee Main CFD Forum 3 September 15, 1999 14:55
