How to create a fluid volume inside a solid volume
Old   November 7, 2008, 08:37
Default How to create a fluid volume inside a solid volume
sanin
hello,
i have to create a rectangular microchannel inside an aluminium brick, the channel running through the brick from one face to the opposite face or let's say the brick is hollow having a rectangular hole within it.Water runs through the rectangular channel carrying away heat from the aluminium block.So i have to make 2 volumes, water and aluminium surrounding it.
How can i create this mesh in GAMBIT?Will just subtracting the channel volume from the block would do?
I need urgent help regarding this.Thank you.
Sanin
Old   November 7, 2008, 14:40
Default Re: How to create a fluid volume inside a solid vo
frederick
i would split the outer brick with the inner volume, deselect "retain". specify continuum types where appropriate.
Old   November 7, 2008, 15:13
Saravanan
Hi I am also trying to solve problem very similar to the one above. So instead of posting a new message, I am continuing in this one. As you said I have created two volumes and split it and specified the solid and fluid continuum types.
Now I want to do Conjugate HT on this model. I know the initial temperature of the solid and the properties of the fluid which is flowing through this micro channel. When I import the Gambit model into FLUENT it has automatically created shadow wall for all the walls which are adjacent to the fluid. Now what BC's do I have to specify for the wall-one and wall-one-shadow.
Thanks in advance.
Old   November 7, 2008, 20:44
frederick
You should specify the temperature, radiation, and slip-condition at the "wall-one" zone. You may have to specify these conditions for the wall shadow as well. I had noticed that the DPM boundary conditions only are available for wall-shadows in at least one setup I encountered. I know you are not using the DPM model (or probably aren't), but I thought I would say this anyhow.
Old   November 13, 2008, 15:17
S
I defined the Boundary conditions on all the wall and shadow wall surfaces and for the fluid I defined the initial temperature at the velocity inlet BC. But how do I specify the initial temperature of the solid volume. I can only define wall BCs.
Thanks S
Create a surface inside a volume Michael CFX 1 February 4, 2009 16:42
heat generating body inside fluid volume NITUL KALITA FLUENT 0 December 14, 2008 13:48
Solid inside fluid volume JP FLUENT 5 December 5, 2008 12:51
[blockMesh] Solid volume inside computational domain francois OpenFOAM Meshing & Mesh Conversion 7 November 19, 2008 16:11
fluid hot volume in fluid cold volume zahid FLUENT 4 June 1, 2002 09:11
