Total and Static Pressure drop
Like Tree1Likes
  • 1 Post By krish
Old   December 4, 2008, 09:59
Default Total and Static Pressure drop
Jaggu
Hi Could any body tell me.Is there any scenario where total pressure drop will be less than the static pressure drop.? Generally which Pressure drop will be used to design the system?where shall i get the complete information on static and total pressure drop?if any body has link or e paper please pass to me
Thanks in advance
Old   December 4, 2008, 15:04
Default Re: Total and Static Pressure drop
mAx
Ptot = Pstatic + Pdynamic
with Pdynamic = 0.5*rho*U^2 >0
How could be the total pressure drop less than the static?
From the mathematical side, it isn't possible
Old   December 9, 2008, 05:27
krish
Hi...Lets arrive at the answer like this,
Total pressure drop = Static pressure drop + Dynamic pressure drop.
Total pr drop will be less than stat pr drop provided the dynamic pr drop is negative. That means the the velocity of the fluid is increasing therefore dynamic pressure drop increases than that of static pressure drop. when there are many recirculations in the fluid domain, total pressured drop will be more than that of static pressure drop.
I guess what i analysed is right..Let me know if u have any other queries on this issue
Old   December 9, 2008, 06:03
krish
Hi, I apologize for the wrong response which i gave recently. Here is the exact and correct explaination for the question you have asked. Total pr = st. pressure + dynamic pressure but total pr drop caanot be equal to st pr drop + dynamic pr. drop.
Dynamic pressure is the pressure which you can measure only at a point. Generally we cannot infer any thing by analysing the total pr drops and static pr drops. By looking at the total pr contours we can infer where there are recirculations etc. okay....
anand.jittanakatti likes this.
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
Total and static pressure drop Janakiram Siemens 1 February 8, 2009 01:32
total or static pressure? George Main CFD Forum 0 November 22, 2005 03:53
static or total pressure? Tim Phoenics 1 September 24, 2003 12:36
Static vs Total Pressure Alfonso Ferrandez FLUENT 2 May 23, 2000 08:53
