parallel Fluent on two PCs connected via ethernet! |
December 2, 2008, 11:55 |
Hi people,
I run parallel Fluent job on two multicores PCs (Q6700 (quad) + T2500). There is Windows XP (32bit) on both. It is running successfully for say 200 timesteps and after that error occurs and the message is as follows: 999999 (..\..\src\mpsystem.c@1224):mpt_read:failed:errno = 10054 999999: mpt_read: error: read failed trying to reda 4 bytes: No such file or directory job aborted: rank: node: exit code[: error message] 0: computer1: 13: Fatal error in MPI_Waitall: Other MPI error, error stack: MPI_Waitall(241)..............:MPI_Waitall(count=4 , req_array=0x019DF1A0, status_array=0x019DF1E0) failed MPIDI_CH3I_Progress(161)........:handle_sock_op failed . . . The parallel FLUENT process could not be started many thanks for any suggestions!!!! jack |
Display Modes | |
can the modeFRONTIER be connected with CCM+? | Mclaren | Siemens | 8 | July 10, 2016 15:23 |
Parallel speedup Fluent Gigabit Ethernet Myrinet etc | tehache | OpenFOAM Installation | 5 | September 7, 2009 05:51 |
Mesh: Surfaces not connected | Babs | FLUENT | 8 | September 17, 2007 05:29 |
connected and connected bientity in gambit | scott | FLUENT | 2 | October 18, 2006 16:51 |
Connected faces in Gambit | Yuehui Qin | FLUENT | 2 | September 25, 2002 19:46 |
