November 24, 2008, 08:44 |
mass diffusivity in FLUENT
Hello, I need to determine the mass diffusivity in FLUENT. Can I get the diffusivity value directly in FLUENT or I need to write down UDF in order to get the diffusivity value?
Thanks. |
November 24, 2008, 10:30 |
Re: mass diffusivity in FLUENT
mass diffusivity in fluent is determined in material panel. or you will get the value in display>countors> Lam Diff Coef of species-n (in the Species... category)
November 24, 2008, 22:53 |
hye, thanks to Shoushibo. I cannot find the Lam Diff Coef of species-n in the display window. I need to define something or what? I need to enable any model in define model?
November 25, 2008, 11:00 |
do you activate the species model? if no ,you need. do you want to simulate a species transport in the mixture? in the material panel , there is a item about mass diffusivity. you may check it. good luck.
November 25, 2008, 20:32 |
thanks shoushibo. Actually Im simulate a species transport for mixture in the Eulerian model. Im already found the mass diffusivity item in the material panel. What I want now is the mass diffusivity after certain time step of simulation. How can I get the mass diffusivity value for that?
November 26, 2008, 09:12 |
it should be in the display/countor/species/lam diff of species n
November 28, 2008, 11:09 |
hi Shoushibo, I still cannot find the lam diff of species n as what you said. Im using Fluent 6.3. In the species model, I enable the species transport also the options diffusion energy sorce and full multicomponent diffusion. Is that I missing something in define the species and transport model? Thanks.
December 2, 2008, 08:57 |
you can try to disable the full multicomponent,and see the results. i solve the binary diffusion in the speices model.
April 15, 2010, 06:15 |
nishith dulet
hi me too facing the same problem...... i am defining two phases. where i want to include mass diffusivity... but i am not getting how to find out this mass diffusivity panel.... every where it is written ...that it is in the materials panel..... but i could not found ..... please throw some light....
November 5, 2010, 09:33 |
anonymous
just as the way given by shoushibo, display/countor/species(not properties)/lam diff of species n is the way to display laminer mass diffusive, my fluent version is Ansys 12. Refer to mass diffusive in materials panel, it is in mixture(material type) only. good luck.
January 29, 2017, 01:59 |
diffusivity
#11 |
Moulish Kommu
Rep Power: 9 |
Hai Iam also facing the similar problem but I want to know the fluent computed value after 1000 iterations, not how to specifiy at inlet
define mass diffusivity for each zone | kim | FLUENT | 1 | October 17, 2011 20:36 |
mass diffusivity C_DIFF_L(c,t,i,j) | pour | FLUENT | 2 | May 31, 2008 15:00 |
mass diffusivity | pour | FLUENT | 1 | May 29, 2008 07:15 |
mass diffusivity | saghir | FLUENT | 2 | July 17, 2006 07:01 |
mass diffusivity | Amanda | FLUENT | 1 | September 11, 2001 20:19 |
