CFD-3D flow problem using Dynamic mesh method.
Old   November 25, 2008, 07:29
Default CFD-3D flow problem using Dynamic mesh method.
Sar_mech
Hi, I am working with a 3-D incylinder problem,on turbulence modeling.I imported the CAD geometry of a simple arrangement of piston and cylinder, from the CAD software and completed the meshing in Gambit, when I tried to run it the Fluent solver with Dynamic mesh model,I am unable to proceed after certain degree of crank angle, the following eror occured:Unable to update dynamic mesh at 370 degree crank angle becasue of negative volume. This error occured when I solved the mesh motion set up in fluent.
Could any one please advice on this,how to solve this problem?
Thanks
Old   November 27, 2008, 21:17
Default Re: CFD-3D flow problem using Dynamic mesh method.
suneel
hiii ,I am doing flow through a pipe with side wall inlets .My problem is to see the path of the air fuel mixture how it is spreading in the pipe.I tried doing it but its not filling the whole volume of the tube.And i am using decane and air mixture for analysis .Can any one help me plzzzzzz
very urgent
Dynamic mesh problem Alain FLUENT 2 December 19, 2006 14:46
Dynamic mesh problem araz FLUENT 0 January 13, 2005 02:51
Dynamic mesh problem Sampath FLUENT 1 October 13, 2004 06:44
Dynamic mesh problem Karthick FLUENT 1 October 11, 2004 05:47
UDF problem for dynamic mesh??? lyf FLUENT 1 April 19, 2004 06:43
