Drag convergence >100 (urgent)
Old   December 29, 2008, 01:44
Default Drag convergence >100 (urgent)
CZ
Hi everyone, I'm doing a investigation on the drag of a ahmed body. I created the mesh with Tet/Hybrid and T.Grid configuration with spacing of 100. There is no boundary layer attached and no size function. With this I run simulation in Fluent using all the turbulence models available, with velocity inlet @ 40m/s but the value of drag is way too high >100 when it's suppose to be around 0.2. Pls advice. Thanks
Old   December 29, 2008, 20:03
Default Re: Drag convergence >100 (urgent)
zongtwi
Please check your reference area used for the calculation of the drag. This can be found in the Report menu, and click reference values...
Hope that helps.
Drag Coefficient Convergence Problem John FLUENT 18 June 24, 2023 09:22
Need urgent help Regarding Drag coefficient srinivas FLUENT 3 September 20, 2006 10:10
Need urgent help Regarding Drag coefficient srinivas Main CFD Forum 1 September 16, 2006 14:15
Need urgent help Regarding Drag coefficient srinivas FLUENT 0 September 16, 2006 12:25
speed up convergence for drag Aymeric CFX 1 March 8, 2006 18:56
