AMG Divergence problem
Old   December 25, 2008, 04:59
Default AMG Divergence problem
mkrao
haiiii...
i am solving mixed convection over circular cylinder when the flow is from top to bottom( buoyancy opposing flow)..after giving all the conditions in fluent i am getting error like "
Error: divergence detected in AMG solver: temperature Error Object: ()
"... why do we get that problem..? i am giving inlet and stream temperatures 300 k and on surface of the cylinder it is 310 k. i am using boussinesq approximation for density. why we will get that problem..? is it due to grid..? i am using circular domain...
please help me in this regard if anybody knows about this problem. thank you in anticipation...
Old   December 30, 2008, 01:51
Default Re: AMG Divergence problem
zongtwi
The error just means that the solution is diverging. Try the following:
Change the under-relaxation factor for Pressure to 0.7 and for Momentum to 0.3.
If still not OK, then use ideal gas for the density.
If still not OK, reduce the URF for all parameters to a low value. Increase the value when the residuals have stabilised. Please ensure the URF value for energy at the end of your simulation is high (ideally 1).
Let me know how it goes.
Hope that helps.
Divergence problem George Siemens 6 March 24, 2007 12:34
divergence problem brusly FLUENT 0 October 10, 2006 00:25
divergence problem vincent FLUENT 3 August 3, 2006 15:44
divergence problem Ayyappan.T FLUENT 2 May 16, 2005 12:10
divergence problem.. jieremy FLUENT 8 May 23, 2003 03:17
