July 8, 2009, 10:59 |
2 domains in 1 simulation
Xavi
Rep Power: 17 |
I have a transient simulation which has two volumes separated by a wall (door) which at some point of the simulation open and let the air pass through them from one domain to the other. The problem is that when I run the simulation with the doors closed (surfaces as walls) there are 2 volumes each one with one velocity inlet and pressure outlet, and the mass balance is unstable and doesn’t converge. When doors are open so then there is only one domain the convergence is excellent. Does anyone knows if FLUENT can operate with two domains at the same time? Any solutions? Many thanx |
FSI TWO-WAY SIMULATION | Smagmon | CFX | 1 | March 6, 2009 13:24 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 14:29 |
Multiple Solid Domains - Interfaces | Scott | CFX | 8 | July 31, 2008 15:20 |
Fire simulation using FDS from NIST | Jens | Main CFD Forum | 1 | January 22, 2004 01:53 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
