January 4, 2009, 06:47 |
stator/rotor interaction in Fluent
I am doing unsteady 2D & then 3D simulation of a single stage turbine. What will be the difference between inviscid and turbulent simulations. i.e what flow features can i capture using these two options. Many Thanks for kind help. |
January 4, 2009, 23:30 |
Re: stator/rotor interaction in Fluent
HI MUHAMMAD QURESHI i am doing a two stage turbine in fluent.. i think the following link will help you ... "http://www.cfd-online.com/Wiki/Best_practice_guidelines_for_turbomachinery_CFD"
i am woking with different pitches(15, 7.5,10,8), ie for 2d (cascade) interface length is not equal.. i feel problems with interface,periodic conditions etc.. i goes through the sliding mesh tutorial(fluent tutoraials) ...Now i feel that interface length must be same.. for that i change my domain by using two first rotor blade.. do u have any Suggestions.. |
January 5, 2009, 23:12 |
hi, i haven't tried unequal pitches using sliding mesh model. The Fluent help people have advised me that equal periodic condition in 3D should also apply in 2D case as well.
hope this helps. if you need any more help let me know. |
January 8, 2009, 00:20 |
THANK YOU
I change my approch to mixing plane model ..seems to be a valid result |
a problem in rotor-stator interaction (help)! | feng | CFX | 0 | January 26, 2006 10:56 |
rotor-stator interaction | Mukkarum | FLUENT | 0 | February 25, 2004 02:44 |
rotor/stator interaction | Hyoungjin Kim | Main CFD Forum | 2 | July 7, 2000 11:32 |
Rotor/Stator Interaction - Validation | Anil Lal | Main CFD Forum | 0 | August 31, 1999 00:37 |
Stator & Rotor interaction | ghlee | Main CFD Forum | 3 | September 9, 1998 11:56 |
