January 14, 2009, 02:53 |
Counter flow HX
Hello guys, I am trying to simulate a counter flow heat exchanger with known inlet temperatures and velocities. wall thickness is to be considered as well.
I am having a problem in setting the outlets bc. if i set them to pressure outlets i have to key in the outlet pressure which is one of the things i am looking for in this simulation. one more problem is in the walls between the 2 fluids (the wall and the shadow wall)what is the best bc to be used here?. I would really appreciate your help in these problems Thanks |
Supersonic flow past a wedge with counter flow | Mahesh Bailakanavar | FLUENT | 0 | February 14, 2008 00:21 |
Counter flow heat exchanger with two different liq | Ram Dayal | CFX | 3 | August 6, 2006 20:42 |
Turbulent counter-flow | cristion | FLUENT | 5 | October 7, 2005 09:47 |
what boundary do I choose for the counter-flow ? | Gali | FLUENT | 0 | October 20, 2004 05:44 |
I need thesis or papers on counter flow | Mahibooswami | Main CFD Forum | 0 | June 6, 2003 18:25 |
