January 20, 2009, 15:37 |
Help with Mesh motion preview
Hi all i have this error when i do Mesh motion preview of the angular velosity of gears in ger pump any one can help me.
Done. Updating mesh to time 1.00000e-04 (step = 00001)... This is Clockwise Gear CG_Omega for clock_wise: 0, 0, -210 CG Position for clock_wise: 7.06373e-306, 1.77272e-295, -2.68156e+154 CG Orientation for clock_wise: 7.06373e-306, 1.77272e-295, -2.68156e+154 This is Anti Clockwise Gear CG_Omega for antic1ock_wise:0, 0, 210 CG Position for antic1ock_wise:7.06373e-306, 1.77272e-295, -2.68156e+154 CG Orientation for antic10ck_wise:7.06373e-306, 1.77272e-295, -2.68156e+154 WARNING: non-positive volumes exist. Dynamic Mesh Statistics: Minimum Volume =-1.56742e-004 Maximum Volume =6.50694e-004 Warning: negative cell volume detected! Error: Update dynamic mesh failed. Negative cell volume detected. Error Object: () |
January 20, 2009, 20:33 |
Re: Help with Mesh motion preview
Does this only occur when you want to preview your mesh motion? What about when you run the simulation, does the same error occurs?
Obviously, I don't really know how your case is, but non-positive volume usually exists because your moving domain is connected to the stationary domain. You need to explicitly disconnect the different zones inside GAMBIT. Hope that helps. |
January 20, 2009, 22:40 |
Hi
If your are getting an error for negative volumes the mesh some where might be collapsing i.e. forming degenrated cells. 1)The C.G. defination might be wrong you can check the motion of your gears with zone motion prior to mesh motion preview which will give you the exact motion set by your definations. 2)And if all the above things are rght try to reduce the time step. 3)Let me knw r u running the case in 64 bit machine Uday regards |
[blockMesh] Preview mesh in Paraview | gareth__it_power | OpenFOAM Meshing & Mesh Conversion | 8 | June 4, 2011 12:13 |
mesh preview mode | lee | Siemens | 2 | June 16, 2007 05:10 |
Cannot preview the dynamic mesh | sam | FLUENT | 4 | May 26, 2005 06:58 |
Cannot preview mesh motion! | dvinh | FLUENT | 0 | August 17, 2004 23:44 |
about preview mesh motion | lingo | FLUENT | 1 | July 8, 2004 12:13 |
