How execute DEFINE_ON_DEMAND udf in (section 2.2.8
Old   January 29, 2009, 12:26
Default How execute DEFINE_ON_DEMAND udf in (section 2.2.8
Alireza HOS
Hi I tried to use a UDF from UDFHelp(section 2.2.8) but it has errors.
1-I compiled it without error
2-I defined (Define->user-Defined->Memory) in this case i select 1
3-using: (Define->user-Defined->Execute on Demand)
but i receive an error:
Error: FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
Would you please guide me why do i have this error. Also i checked it with different computers.
The macro is mentioned in following:
UDF to calculate temperature field function and store in
user-defined memory. Also print min, max, avg temperatures. ************************************************** *********************/ #include "udf.h"
DEFINE_ON_DEMAND(on_demand_calc) {
Domain *d; /* declare domain pointer since it is not passed as an
argument to the DEFINE macro */
real tavg = 0.;
real tmax = 0.;
real tmin = 0.;
real temp,volume,vol_tot;
Thread *t;
cell_t c;
d = Get_Domain(1); /* Get the domain using Fluent utility */
/* Loop over all cell threads in the domain */
thread_loop_c(t,d)
/* Compute max, min, volume-averaged temperature */
/* Loop over all cells */
begin_c_loop(c,t)
volume = C_VOLUME(c,t); /* get cell volume */
temp = C_T(c,t); /* get cell temperature */
if (temp < tmin || tmin == 0.) tmin = temp;
if (temp > tmax || tmax == 0.) tmax = temp;
vol_tot += volume;
tavg += temp*volume;
end_c_loop(c,t)
tavg /= vol_tot;
printf("\n Tmin = %g Tmax = %g Tavg = %g\n",tmin,tmax,tavg);
/* Compute temperature function and store in user-defined memory*/
/*(location index 0) */
begin_c_loop(c,t)
temp = C_T(c,t);
C_UDMI(c,t,0) = (temp-tmin)/(tmax-tmin);
end_c_loop(c,t)
Old   February 1, 2009, 10:23
Default Re: How execute DEFINE_ON_DEMAND udf in (section 2
bohis
thread_loop_c(t,d) is not closed with bracket! Moreover, t_avg and vol_tot have to be initialized!!!
good luck
DEFINE_ON_DEMAND and acces to particle (DPM) JFeg FLUENT 0 October 31, 2008 12:53
DEFINE_ON_DEMAND pourak FLUENT 4 April 19, 2007 04:34
DEFINE_ON_DEMAND jim FLUENT 0 June 13, 2006 02:36
define_on_demand help!! Thiyagarajan FLUENT 0 August 23, 2005 14:39
DEFINE_ON_DEMAND iker FLUENT 0 July 17, 2003 12:13
