Drag coefficient not making any sense
Old   December 27, 2008, 11:21
Default Drag coefficient not making any sense
radix
Hi everyone! I have posted a message previously about airfoil. Finally,i have achieved 8.7% error for my lift coefficient in Fluent compared to DesignFoil. But,the drag coefficient was getting smaller,around 0.0025. I think it's too small for my NACA 9410 with its angle attack 0 degree. Can anyone help me about this? What should i do to make right or at least nearly right? Thanks,
Old   December 30, 2008, 00:49
Default Re: Drag coefficient not making any sense
zongtwi
Both drag and lift coefficients is dependant on a referenced area. For drag, it is usually the projected frontal area. For lift, it is usually the projected horizontal area. Is this how you calculated your drag and lift coefficients to be compared to the FLUENT results?
In the Report menu, under Referenced Values... there's only one value for reference area. Please use the reference area for lift, when calculating the lift coefficients, and use the reference area for drag when calculating the drag coefficient. Try this out, and see if it improve your results or not.
Hope that helps.
Old   February 4, 2010, 19:56
thanos
thanos is on a distinguished road
Originally Posted by zongtwi
;155679
How can you calculate the projected area if you have an AOA not 0 ?
thanos is offline   Reply With Quote
Fluent Good Lift coefficient BAD drag coefficient Rif Main CFD Forum 4 March 9, 2010 10:52
drag coefficient Amir FLUENT 6 November 7, 2008 05:47
DPM drag coefficient Spielkind FLUENT 1 August 12, 2007 12:27
drag coefficient puneshwar verma FLUENT 2 February 28, 2007 00:04
Coefficient of drag sam Siemens 4 May 26, 2005 05:47
