scheme stack space
Old   February 4, 2009, 12:17
Default scheme stack space
david
I am importing a scheme macro every 5 time steps in an unsteady analysis using the execute commands. After a certain amount of time i run into an error telling me i'm out of scheme stack space and i need to increase the limit. I read online that i type -s8000 when openingn fluent through the command line if i want a limit of 8000, so i do this and fluent loads. Is this the correct way to set the stack space and if so how do i check whether this was successful?
Regards David
RAM and Swap Space and HD space Anindya Siemens 2 May 25, 2016 21:40
scheme stack space mary FLUENT 0 June 10, 2005 03:17
Out of Scheme stack space Domi FLUENT 0 November 26, 2004 08:24
Scheme stack space problem calvin FLUENT 0 July 19, 2004 20:53
Stack space Pravesh Kumar FLUENT 0 November 3, 2002 05:40
