air and water vapour mixture - multiphase model
Old   February 10, 2009, 12:05
Default air and water vapour mixture - multiphase model
Saba
Hello all,
I'm modeling heat and moisture flow in a tall and thin cavity. The cavity is filled with mixture of air and water vapour (moist air). I'm using the mixture multiphase model, with the two phases being air and water-vapour. I am trying to see the stratification of both heat and moisture in the cavity. Can you tell me if this is the correct model to use? I used the species model before, but I noticed that in order to see moisture buoyancy flow I should use a multiphase model.
I appreciate your help,
Saba
Multiphase phase Mixture model Robi FLUENT 8 October 23, 2017 07:10
Modeling Condensation in water vapour-air mixture Amol Main CFD Forum 14 April 10, 2012 00:28
Mixture model - water droplet + air - EVAPORATION bohis FLUENT 4 January 25, 2008 11:04
evaporation multiphase model ( vof? mixture ? ) emanuele FLUENT 0 March 2, 2007 11:44
Multiphase Mixture Model fluent5.4 Julia Kullmann FLUENT 0 March 9, 2001 05:13
