Problem reading .cas because of UDFs
Old   February 12, 2009, 05:40
Default Problem reading .cas because of UDFs
Star-Fluent-X
I've got some problem opening tutorial using UDFs (for example OhmicHeater).
When I try to open the .cas file the error says : Opening library "libudf"... error : open_udf_library : No such file or directory Error Object : #f
There is no problem with opening a .msh but the same error appears when when I try to load UDFs. Would anyone have a clue ? Thanks
Old   February 12, 2009, 09:14
Default Re: Problem reading .cas because of UDFs
Nagi
#include "udf.h" #define f 10.0 /*vibration frequency in Hz*****/ #define A 10.0 /*vibration amplitude in m/s^2*****/ #define pi 3.14 DEFINE_SOURCE (x_mom,c,thread,dS,eqn) { real source,t,xaccel; t=CURRENT_TIME; xaccel=A*sin(2*pi*f*t); source=xaccel*C_R(c,thread); dS[eqn]=xaccel; return source; } Pleas the above code which describes the inertial body force due to vibration applied in x-direction as a momentum source. Thanks every body Nagi
Old   February 12, 2009, 10:01
Antimony
Are you using a compiled version for your UDF? That is when libudf is used. You might want to see if it has been loaded into your case file and if possible remove it. You can unload it by going to UDF->Functions->Manage->Unload.
Hope this helps.
Regards
Antimony
Please help!!!COMPILED UDFs PROBLEM!!! Melih Fluent UDF and Scheme Programming 9 August 2, 2013 01:56
Re:Case reading problem krishna FLUENT 0 December 19, 2008 11:59
How to use more than one UDFS in one problem Thanh FLUENT 2 August 13, 2008 21:28
UDFs' problem Benny FLUENT 14 June 13, 2005 11:05
Problem in writing UDFs Nima Sheyad FLUENT 1 November 25, 2002 01:04
