angle rotated
Old   February 18, 2009, 06:46
Default angle rotated
Usman
Hi, I am modelling stator/rotor interaction in Fluent. Is it possible to know how much the rotor (in degrees) has moved with respect to stator trailing edge.
Many Thanks,
Old   February 18, 2009, 09:37
Default Re: angle rotated
Grzegorz
Yes, you can probe by mouse specific place of your rotor (i.e. corner or somethink) and you will get cooridnates of this point. Then use simple math to calculte the angle/angles. Another way is to calcuate the angle based on the flow time - assuming that at time t=0 you have angle alfa = 0, and now you have time t = t1 you can calculate current angle acording to the following formula: alfa_new = t1[s]*(omega[rpm]/60). If your rotor did a full revolution you need to substact 360 from alfa_new. Hope this help.
Recommended setup for the Singly rotated frame jaswi OpenFOAM Running, Solving & CFD 1 June 13, 2007 05:12
Singly rotated frame setup jaswi OpenFOAM Running, Solving & CFD 1 June 6, 2007 13:59
Impact Angle Daniel FLUENT 0 March 13, 2007 12:40
About the Contact Angle Flora FLUENT 2 March 8, 2007 02:07
XY Plotting with ANGLE - Possible ?? Cyril FLUENT 2 February 23, 2006 16:05
