February 24, 2009, 23:34 |
GAMBIT,can't re-open mesh to modify
Hi, can sombody tell me how to use GAMBIT to re-open a mesh file that i've created using GAMBIT.
muntasirmahadi@yahoo.com |
February 25, 2009, 00:26 |
Re: GAMBIT,can't re-open mesh to modify
if the file is .msh file, you can't open that file directly in GAMBIT. You have to Import that file. File->Import->Mesh
February 25, 2009, 01:45 |
Thanks, i've just tried it. Error msg received; The Gambit neutral file header (record 1)is non-standard. My mesh is 2D ,Solver:Fluent 5/6.
February 25, 2009, 02:01 |
To solve your problem, do this: - read the .msh file in Fluent - save it as .cas file - read it back into Gambit, importing as Fluent 5/6 .cas 2D file. ##Thanks to Razvan##
February 25, 2009, 02:17 |
Many thanks, you've solved my problem.
February 25, 2009, 02:18 |
you are most welcome
How to open mesh file in Gambit /pls help | FRAJ | FLUENT | 14 | February 19, 2017 01:36 |
An Open Source mesh generator for Open Foam | Ahmed | Main CFD Forum | 15 | September 23, 2010 18:39 |
Cannot open Gambit? Why? | emad | FLUENT | 10 | January 2, 2009 09:11 |
how to open .cas file in gambit? | revathi | FLUENT | 4 | August 16, 2007 01:28 |
open mesh files in gambit | A.Naser | FLUENT | 3 | February 20, 2004 05:39 |
