February 25, 2009, 07:38 |
2D Axisymmetric & 3D cylinder
Hai
I want to know the difference between 2D Axisymmetric (cylinder) problem and a 3D cylinder problem. I modelled both for a heat transfer problem and analysed in FLUENT. But the results are not matching. The problem is Cylinder length = 500 mm Flowing fluid = Air Inlet temperature = 300 K Wall surface temperature = 400 K Inlet velocity = 0.05 m/s The result i.e., outlet temperature is varying for both the cases. Is there any difference in solving both the cases by FLUENT. How to get the same results from both cases. Kindly suggest me some solution Regards Raj. |
February 25, 2009, 12:34 |
Re: 2D Axisymmetric & 3D cylinder
It is interesting. Before I know your result, I also believe that the results of both case should be the same if the geomerey and boundary condition are axisymmetric. I just want to reminder you that the boundary type for the centerline of cyliner in 2D case should be axis, not symmetry. If all of your setting up is correct, I suggest running a case only with flow, then considering heat transfer.
Hope it help. |
February 26, 2009, 03:43 |
Thanks for your immediate reply Mr. Jiuan
The geometry and Boundary conditions are given the same. The geometry is 50 mm dia. pipe with 500 mm length. For 2D-Axisymmetric case, axis boundary condition was given in x-axis. Flowing fluid is air.Flow is laminar. Velocity inlet (0.05 m/s)and pressure outlet (0) BC given. First, I checked for without heat transfer.The results such as skin friction coeffcient at the wall and pressure at the inlet are not matching with that of the 3D case. Then I included heat transfer i.e., wall is kept at constant temperature of 400 K. The inlet air temperature is given as 300 K. The result i.e., the area weighted average of air temperature at the outlet doesnot match with that of the 3D case. If you have already checked some benchmark problems of this kind, kindly suggest them for checking the results. Thanks & Regards Raj. |
February 26, 2009, 04:06 |
Hi!
have you checked the reference values? Are they the same for both? Maybe it is about the are calculation.... Is the grid the same for both cases?? Ralf |
February 27, 2009, 01:37 |
Thanks for your reply Mr. Ralf
I checked the reference values for the cases and they are same. The geometry is same for both cases. The grid is generated is approximately same for both the cases. Wall is kept at constant temperature of 400 K. The inlet air temperature is given as 300 K. The area weighted average of temperature at outlet for 1. 2D axisymmetric case : 383 K 2. 3D cylinder case : 399 K I donot know why this difference is occuring? Kindly suggest me some solution. Thanks & Regards Raj. |
August 17, 2009, 07:59 |
pinho
Is it possible when dealing with 2d axisymmetric, to post-processing the results in a 3d view? How does it work?
Thanks jpinho |
August 17, 2009, 12:37 |
Check for grid independence!
Bobby
This is very interesting problem. I was wondering if you had done any grid independence on both the 2D and 3D cases. If you find that the 3D model requires more refined grid and you make certain that results are good (within certain confidence interval) then try to use these the settings (i.e. grid pattern etc) on the 2D case. If you do find the reason/solution for this mismatch of results, please let us know. I'm very curious about it. Regards, PawnPace |
January 2, 2013, 13:44 |
#8 | |
rameshkumar m bhoraniya
what does it mean axis and axisymmetric? |
January 3, 2013, 01:47 |
SSL
When you model in axisymmetric mode, for example for a cylinder you just model a square that an edge would be the axis of the cylinder. Got it?
January 3, 2013, 05:52 |
Nilambar Bariha
In fluent can I simulation the dispersion problem. If yes how ? In my problem the highly compressed liquid in comes out from the pipeline.
February 16, 2015, 13:17 |
#11 |
azna
Hi ,
Is it possible when dealing with 2d axisymmetric, to post-processing the results in a 3d view? How does it work? |
April 14, 2015, 07:25 |
2D axisymmetric and 3D mismatch
#12 |
Darshankumar Ragunath
Hi.. I am also solving a different problem but i also see that the results are varying. I'm modelling a flow around a hemispherical canopy with a vent hole to determine the drag force it experiences. I modeled the canopy geometry as a simple hemispherical shell will a vent hole in it. But the drag forces are varying by 16% when comparing the results of axisymmetric model and complete 3D model.
May 26, 2015, 12:09 |
#13 |
azna
Hi ,
I am simulation a cylinder. I used 2Daxisymmetric model and normal 2D which looks like a rectangular. the comparison of the results by experimental values showed that normal 2D simulation produces less relative error than 2D axisymmetric model. While all the setup is the same in both simulation. the relative error of the the former is 26% while the latter is 40%. Thanks |
July 8, 2016, 08:09 |
#14 |
Rep Power: 9 |
I would like to ask if it is possible to view the results of a simulation using a 2D axisymmetric model in 3D? |
3-d mesh gambit (cylinder within a cylinder) | Jason | ANSYS Meshing & Geometry | 29 | October 30, 2015 08:59 |
Flow over axisymmetric cone cylinder configuration | Wamiq Rasheed | FLUENT | 1 | May 14, 2007 13:48 |
Axisymmetric Mesh extrusion (2d-3d cylinder) | ben akih | CFX | 0 | August 21, 2006 19:03 |
Help meeee: Wave cylinder (sine cylinder) | Ngoctq | FLUENT | 0 | December 29, 2005 20:46 |
AXISYMMETRIC FLOW IN A CYLINDER | Abhijit S. Joshi | Main CFD Forum | 1 | October 28, 1999 14:59 |
