February 19, 2009, 08:05 |
Incompressible Ideal gas law
Hello dear people,
I would like to ask about the incompressible ideal gas law. As i have understood, and please correct me if I am mistaken, when you use the incompressible ideal gas law the fluid is incompressible due to the low mach number but depends from the temperature variations. What happens then to the density in the continuity equation? Is it still removed from the equation (because it is incompressible) and it is grad(V) = 0? or Fluent solves grad(ρV) = 0 and it is taking account of the density variations from the temperature? Thanks in advance |
February 20, 2009, 05:51 |
Re: Incompressible Ideal gas law
It solves grad(ρV) = 0 and it is taking account of the density variations from the temperature by calculating gas equation.In transient cases, time also plays role.
February 20, 2009, 08:54 |
Thank you very much for your reply. So the name "incompressible" is not accurate since it's solving grad(ρV)=0.
Again thank you for your reply. Best. |
February 23, 2009, 04:52 |
the fluid is incompressible, because it can not be compressed by pressure. So density depends only on temperature
Ralf |
March 3, 2009, 09:57 |
Yes i agree with you. But the term incompressible is used only if we solve grad(u)=0. Since we don't solve grad(u)=0, and we solve grad(ρu)=0, then the fluid is compressible careless of what the density depends on, pressure or temperature.
I am just trying to understand what Fluent solves for. Thank you for your reply. |
March 5, 2009, 16:41 |
I keep doing the same error. It is not grad(ρu)=0. It's div(ρu)=0. Sorry for this mistake but I don't use this notation at all!
Incompressible Ideal Gaz in a closed system - Help | JB | FLUENT | 2 | August 1, 2008 04:16 |
difference between ideal gas and incompressible? | Ric | Main CFD Forum | 1 | March 24, 2007 12:07 |
ideal-gas-law??? | abel | FLUENT | 0 | May 22, 2006 07:48 |
Problem using ideal gas | mark | FLUENT | 3 | November 29, 2004 16:40 |
ideal-gas setup | Tommaso | FLUENT | 1 | June 22, 2003 07:10 |
