how to open a cas file in gambit
Like Tree1Likes
  • 1 Post By Amir Khodabandeh
Old   March 13, 2009, 07:18
Default how to open a cas file in gambit
Michal K
hello, i lost my gambit file but i have a .csa file, how can i get my mesh back from thet file. Thanx for your help
Old   March 13, 2009, 08:41
Default Re: how to open a cas file in gambit
Amir Khodabandeh
First of all I consider .cas not .csa (I don't know if csa is a valid extension) go to FILE-->IMPORT-->MESH--> and change the format from ANSYS to fluent 5/6
if you have .jou file you can load journal too which gambit redo what ever you have done I think this will help
nellosamr likes this.
Old   March 13, 2009, 08:55
Michal K
thanx i will try that
Old   March 13, 2009, 13:05
Jason
Search the forum, this topic has been covered many times.
Good luck, Jason
Old   March 13, 2009, 13:54
Default Re: how to open a cas file in gambit *NM*
Jason
Sorry, responded to the wrong thread (must've hit the backbutton too many times)
Thanks Jason
Old   March 14, 2009, 16:37
Gajanan Kale
you can import the mesh file into gambit and i am not sure about .cas file. also, after importing, you will see virtual geometry.
How to open mesh file in Gambit /pls help FRAJ FLUENT 14 February 19, 2017 01:36
[GAMBIT] Gambit to open and old msh file Muntasir ANSYS Meshing & Geometry 5 August 2, 2012 02:21
Gambit error on linux: Unable to open file ... Wim Heirwegh FLUENT 1 October 10, 2007 11:06
How to open .SAT file by GAMBIT? Ertan Taskin Main CFD Forum 2 September 25, 2007 08:35
how to open .cas file in gambit? revathi FLUENT 4 August 16, 2007 01:28
