meshing and convergence
Old   April 6, 2009, 12:34
Default meshing and convergence
amira maizi
amira is on a distinguished road
can meshing pattern be a cause of divergence??
I am now simulating a bubble column of 4 m of height and 0.15 m of diameter, with a gas sparger having the form of 9 tubes intersecting with a long tube in the middle of each, on the tubes there are holes of 1mm diameter each.
that configuration obliged me to use tetrahedral meshes in the bottom side of the column, wich increased the cells number to 314000.
now while simulating, I always get divergence telling me " divergence detected AMG solver: k"
does this mean that my meshing is too bad, because everytime I change K and epsilon, I get the same divergence message...
pls help me, I really don't know what to do
amira is offline   Reply With Quote
Old   April 6, 2009, 13:44
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
try other turbulence models, also other solver parameters.
-mAx- is offline   Reply With Quote
convergence Tanveer ahmad Rubani CFX 6 March 4, 2009 05:07
convergence problem ammi reddy FLUENT 1 March 28, 2007 17:01
CFX10 & CFX Built and convergence Neser CFX 1 February 18, 2007 16:42
Challenging Meshing... Chebeba CFX 9 March 30, 2006 02:19
meshing for surface ship flow boris FLUENT 0 April 24, 2002 20:27
