catia mesh to fluent
Old   June 26, 2002, 14:14
Default catia mesh to fluent
mrakan
Does anybody know is it possible to import mesh from Catia and use and analyze with Fluent.
Thank you,
Mrakan
Old   June 28, 2002, 03:58
Default Re: catia mesh to fluent
Joern Beilke
You probably have a catia model but not a mesh. There are several ways to deal with this but all require some additional software. It also depends on the kind of data you have in catia -- solids or surfaces .
Old   June 28, 2002, 07:06
mrakan
Hi Joern,
My intention is to use fluent software for heat and flow analyzes. But I realized that something to be analyzed in fluent has to be input as a mesh. I have catia V5R6 P2. You mentioned additional software. What else I need. I don't use and don't know too much about catia, but if I need as input in fluent and if I have capabilities with V5R6 P2 catia , it is worth to study and learn catia. If I need additional software, please advice which one. I know that many programs are capable of doing mesh, but I have catia as one option.
Thanks, Zoran
Old   July 1, 2002, 04:47
Laika
I'd sugest to export your catia model as a step or iges-file. You can import this into Gambit. Play with the import options to find how to import the geometry as cleen as possible.
You chould do some cleaning of your model in Gambit. Afterwards you create your mesh in Gambit.
Your Catia-model should be very clean. It really should be made for cfd-analysis.
good luck
Laika, still orbiting
Old   July 24, 2002, 23:41
Dr. Al Witry
You will probably find that IGES is a very dirty method of translation and that STEP is not readable by a lot of meshing software.
Alternativel, CATIA can create meshes through its FEA facilities. It can also save nastran (.nas) and neutral (.out) or (.nut) files if I remember right. This is especially true for CATIA 4 and I would have thought that CATIA 5 did retain these capabilties if not added to them. If this was the case, then you can save as NASTRAN and read it into Tgrid to create Fluent's native (.msh) mesh file.
If not, then yes, you will need another software to "translate=bridge" the data. Most things here include purchase of a different software like "ICEM CFD" which I find to be very useful here. These software can be expensive but there was once a software called Rhinosaurus or something of the kind that was available for free over the internet and did do data translation operations.
Hope this helps.
Old   June 18, 2014, 12:54
AZ
mjthomp3 is on a distinguished road
Originally Posted by Dr. Al Witry
;101899
Hope this helps.
For Some reason after I imported my catia mesh into Tgrid and exported as .msh file for FLUENT to read it read an error.....
please help on is there something wrong that i am doing here??
mjthomp3 is offline   Reply With Quote
Old   September 28, 2016, 02:18
Default import mesh to FLUENT from CATIA
hamid_reza
hamid_reza is on a distinguished road
hello friends,
for import mesh to fluent from catia you must doing below stage,
1- generate mesh at "advanced meshing tools" environment in catia software,
2- click on expot mesh icon in import/export tool bar,
3- select save as type "Bulk Data(*.dat)" and write a name in "File name" positon,
4- open fluent software and go to "import" in "file" at menu bar then select "NASTRAN" and then select "Bulkdata File...",
5- select previous exported file and open that, your mesh imported in fluent.
6- end.
this method used in catia V5R20 and fluent 6.3, but i can not defined boundary condition, if you can, please write in cfd onlin.
thank you.
hamid_reza is offline   Reply With Quote
[ICEM] export hexa mesh to fluent Wieland ANSYS Meshing & Geometry 37 January 23, 2013 03:27
[Commercial meshers] Cannot convert fluent or tgrid hexcore mesh aerogt3 OpenFOAM Meshing & Mesh Conversion 2 October 22, 2010 11:55
Can anybody tell me what does fluent do using MESH MOTION? enry FLUENT 0 October 6, 2010 12:54
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Import ICEM Mesh to Fluent Fluent Beginner FLUENT 5 June 23, 2004 00:27
