May 4, 2009, 00:49 |
Mixture multiphase model
Dear all,
Before i go any further, i think better i explain a little bit about my projects. I'm doing simulation on mist elimination system where a gas stream with a fraction of mist ( water fraction = 0.004, droplet's diameter = 0.1 mm ) is allowed to pass through torturous channels with a velocity of 4-7m/s. I chose to use mixture multhiphase model to deal with my two phases problem. I've got the following result as I summarize the mass- flow through the inlet and outlet of the passage. For the mixture: zone 5 (inlet): 0.12247331 zone 4 (outlet): -0.12246391 net mass-flow: 9.3979068e-06 For the primary-phase which is air zone 5 (inlet): 0.12246401 zone 4 (outlet): -0.12246391 net mass-flow: 1.0460325e-07 For the secondary phase which is water zone 5 (inlet): 0 zone 4 (outlet): 0 net mass-flow: 0 I'm wondering why the mass-flow for water is zero. It seems like fluent already pre-defined the mixture's phase fraction as zero for the water. Would anyone advise me on this matter? Thanks and regards, sourplum Last edited by sourplum; May 5, 2009 at 03:43. Reason: Attach summary.txt file |
May 19, 2009, 07:27 |
John Gallagher
Im pretty new to Fluent but I can simply see why the net-mass is 0. As with the mixture and primary phase it is zone 5 minus zone 4. I think what you need to do is analyse internally in the model with the surface tools. Hope im not stating the obvious, John G |
Multiphase flow. Dispersed and free surface model | Luis | CFX | 8 | May 29, 2007 18:13 |
Turbolence model for multiphase flows | lu | CFX | 1 | February 7, 2007 16:40 |
multiphase model | Sumeet | FLUENT | 2 | August 31, 2005 08:26 |
Converge problem of Mixture Model | Jen | FLUENT | 8 | August 17, 2005 18:23 |
Multiphase Mixture Model fluent5.4 | Julia Kullmann | FLUENT | 0 | March 9, 2001 05:13 |
