May 14, 2009, 22:55 |
conjugate heat transfer of a turbine blade
Hi Fluent user friends,
I am encountering a convergency problem using Fluent solver to solve a subsonic turbine flow. The application is a conjugate heat transfer involving solid blade, mainstream compressible flow (M0.5-M0.9) over the blade surfaces and incompressible low speed cooling air passing through the inside of blade. I always have the convergency problem for both coupled and uncoupled solvers. Does anybody have experience of this complex conjugate heat transfer which have two different fluid domains, one is compressible and another is incompressible? Any hint would be helpful to guide me. This is how I did. Density-based solver. Ideal gas law is used to obain the density of compressible mainsteam flow, while incompressible ideal gas law is applied for the cooling flow. Periodic BC was applied in the sidewalls of computational domain. Pressure inlet and outlet boundary conditions were used for both flows. Standard KE Turbulence models are applied. Thank you very much in advance. Steven |
February 23, 2013, 14:31 |
Sai
Hope you solved the problem. I am carrying out a similar analysis on a turbine blade. At first I had such errors when the problem was mostly with the mesh. You could have tried reduce your under relaxation facts a bit.
I would like to know if you made a moving reference frame. And if so , you applied speed to the solid cell zones or the fluid ? Thanks in advance. |
Conjugate heat transfer and radiation modeling questions | shankara.2 | FLUENT | 0 | April 21, 2009 15:55 |
Conjugate heat transfer problem with porous media | piko | Siemens | 1 | April 17, 2009 15:41 |
Conjugate heat transfer with periodic boundaries | Suresh | FLUENT | 0 | February 23, 2009 09:51 |
Conjugate heat transfer (vs) periodic boundary | mp | FLUENT | 1 | January 13, 2003 01:38 |
