How to set the angle of rotation that can free |
March 25, 2016, 03:46 |
yang hong sun
Rep Power: 11 |
I would like to know if there is a way that can be set in the range of rotational freedom (6DOF)
Example, To allow only rotate freely between 0 and 90 degrees. prop[SDOF_ZERO_TRANS_X] = TRUE; prop[SDOF_ZERO_TRANS_Y] = TRUE; prop[SDOF_ZERO_TRANS_Z] = TRUE; prop[SDOF_ZERO_ROT_X] = TRUE; prop[SDOF_ZERO_ROT_Y] = TRUE; prop[SDOF_ZERO_ROT_Z] = false;---------------(0~90 only) Thank attention. |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
[mesh manipulation] mirrorMesh and undoing the joining of patches | chegdan | OpenFOAM Meshing & Mesh Conversion | 3 | October 21, 2015 08:09 |
3D Fan:Calculation of induced flow rate by fan rotation at free delivery | Catthan | FLUENT | 3 | November 6, 2013 05:19 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
how to set contact angle | njtu | FLUENT | 0 | August 26, 2005 12:47 |
