y+ values!!
Old   June 18, 2009, 05:24
Default y+ values!!
Chris Turner
chrisoturner is on a distinguished road
I am currently modelling a diffusing cone under steady flow conditions (eventually the model will be under transient flow conditions, but I am using steady flow at the minute to get a better understanding of Fluent).
The y+ values on the wall of the diffuser have a very large range when plotted, the minimum is 28 and the maximum is 834! I'm not sure if this is anywhere near normal? There is a lot of turbulentce in the diffuser, with a large annular votrex forming.
Also, I have used a cooper mesh, which means the cell size actually increases as the diffusers cross sectional area increases, could this be what is causing the variance in y+ value?
Any help would be great!
Thanks in advance
chrisoturner is offline   Reply With Quote
Old   June 18, 2009, 07:55
Piotrek is on a distinguished road
you can adapt the mesh in fluent basing on y+ value
Just go to Adapt->Iso-region
basically you want to have the y+ value around 5-30 depending on the model you use
Piotrek is offline   Reply With Quote
Old   June 18, 2009, 10:55
Max
coglione is on a distinguished road
Just a comment on pioteks post.
using standard wall functions, y+ should be above 30 larger values up to some limit are acceptable! Thus the grid of Chris is not so bad, a refinement of boundary layers should be restricted to values of y+ > ~200 and only necessary, if these values are found in regions of interest = prostcessing.
cheers
coglione is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
Ensight - node values -cell values leo FLUENT 1 May 12, 2010 08:47
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 12:04
node values or cell values? aPpA FLUENT 0 November 10, 2006 08:56
Plotting raw data values Wilesco Siemens 0 January 5, 2006 05:34
