Multiple surface particle injections from the command line |
June 3, 2009, 14:11 |
Matthew
I need to obtain particle injection data for several sizes of particles in 10 different solved cases (30 releases).
I'm attempting to do this through a batch file, but am hitting a problem. I need my release grid to be 150x30 with particles on a 1x1 spacing. When you define a point-array, you define the number of particles per side, meaning that to get a 1x1 distribution, I have to define square arrays. So I define 5 30x30 point-arrays, which give me the particle layout that I'm looking for. However, when I go to define an injection using the command line, I can only get it to use a single release surface (instead of all 5). I also can't find a way to stitch the 5 surfaces together into a single one. |
DPM: Particle tracks stop at a "reflect" surface | Confused | FLUENT | 3 | February 7, 2022 12:12 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
surface monitor - multiple lines in one chart? | jx | FLUENT | 6 | January 12, 2004 05:51 |
