July 5, 2007, 05:07 |
Gambit batch mode problem
Hi everybody
I have a simple journal file. When I run this journal file in GAMBIT gui it works correctly. However, when I run the same journal file with "gambit.exe -r2.3.16 -inputfile myfile.jou" command in command windows of XP I receive a lot of warnings such as edge xxx is already exists ... ... zone xxx is already exists ... ... I think that my journal file run two times successively when I use the command above. How do I prevent this? Thank you for you help Mr. OBUT |
June 8, 2009, 16:42 |
Rep Power: 16 |
Were you able to solve this problem ? I am facing the same situation now.. What did you do to overcome the problem? |
Display Modes | |
GAMBIT Batch Mode - MATLAB | asd | Main CFD Forum | 12 | October 1, 2018 09:12 |
cfdpost in batch mode | taichijulie | CFX | 1 | October 25, 2010 16:29 |
problem using property udfs in parallel mode | EllenW | FLUENT | 0 | June 23, 2009 18:18 |
Problem with Gambit | Diego | FLUENT | 0 | July 5, 2007 04:30 |
Problem starting Gambit | ViHAR MALViYA | FLUENT | 0 | November 10, 2006 11:26 |
