May 8, 2009, 03:22 |
Issues with dynamic meshing
Sridhar S
I am working on a 2D problem where you have a beam like structure inside a square enclosure. The beam is fixed at one end and oscillates up and down(I used rigid body motion UDF to do this). But the dynamic meshing isn't working properly when I use rectangular elements near the beam. It seems to work reasonably well when I have triangular elements near the beam. But the Gambit boundary layer meshing option allows only rectangular elements near the boundary. So how do I make my model work for rectangular elements also? Also I am confused about which dynamic mesh algorithm(Smoothing, Layering, Remeshing) I should be using..I would be happy if somebody can explain about this also. Thanks, Sridhar |
June 11, 2009, 17:46 |
Rep Power: 16 |
what is the configuration you have for the dynamic mesh parameters? are you using layering accompanied by smoothing or remeshing? If you are only using layering, try typing define/models/dynamic-mesh-controls <enter> define/models/dynamic-mesh-controls/ sp <enter> define/models/dynamic-mesh-controls/sp/soas <enter> [yes] this will "activate" the layering option for the structured mesh. |
Display Modes | |
negative cell volume during dynamic meshing | Tamjid | FLUENT | 1 | September 5, 2011 03:33 |
Dynamic meshing | Manoj Kumar | FLUENT | 3 | June 27, 2010 20:26 |
help for dynamic meshing for incylinder combustion | Ramesh K | FLUENT | 0 | June 19, 2006 07:29 |
Dynamic Meshing Problems | Shuto | FLUENT | 3 | January 19, 2005 21:09 |
dynamic meshing option | arehman | Main CFD Forum | 4 | June 27, 2004 03:55 |
