Solid / Fluid Heat Transfer
Old   July 5, 2009, 15:57
Default Solid / Fluid Heat Transfer
Koranten is on a distinguished road
Hi everyone,
I would like to know something about heat transfer in FLUENT.
To what extent can this software deal with heat transfer between a fluid zone and a solid wall?
From what I have seen in the User's Guide, FLUENT is using experimental correlations and calculate a Nusselt number...
What is the accuracy of this approach? Is there a way to make something better? What do others CFD codes do for this specific problem?
Is there some documentation where real/experimental cases are compared to FLUENT calculations, in order to see how well is FLUENT doing?
In fact, I would like to know if I can trust FLUENT for heat transfer between solid and fluid, or if this is something "dangerous".
I would also like to know if FLUENT is really more powerful than "hand calculations" for heat transfer in tubes, or if I can just stay with my hand and my Nusselt correlations...
Regards
Koranten is offline   Reply With Quote
Old   July 8, 2009, 10:35
Nobody can answer me?
Old   March 19, 2011, 05:39
H&A
FluentNewbie is on a distinguished road
Hi koranten,
In reality, a CFD has never been trusted blindly. It has been, all the time, compared to experimental studies and this showed, in general, good agreements between them.
So, my advice, is to set some simulations according to your problem type, and if this gives good results compared to your calculations and/or experimental data, you can use these type of simulation.
To summarize, you can rely on simulation results ONLY after being extensively assessed for a particular type of problem.
I hope my opinion could help.
FluentNewbie is offline   Reply With Quote
Old   March 19, 2011, 07:21
Robert
Kwiaci is on a distinguished road
You need to know what inputs to use. FLUENT is very accurate program but only if you use good solver configuration to avoid "shit in - shit out". But you should look on some verification experiments for similar cases.
Kwiaci is offline   Reply With Quote
Heat transfer trough a solid domain Tiago CFX 2 March 17, 2008 14:54
modeling heat transfer betwwen fluid and solid Al Mazdeh CFX 0 March 13, 2008 10:35
How to model heat transfer in solid regions Tong T FLUENT 7 October 3, 2007 22:49
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 07:15
Solid domain heat transfer falling_stone CFX 1 May 8, 2005 19:04
