Minimum PDF table enthalpy exceed in X cells in zone Y
Like Tree1Likes
  • 1 Post By MarkelRF
Old   April 18, 2018, 05:46
Default Minimum PDF table enthalpy exceed in X cells in zone Y
MARKEL ROA FRESNO
MarkelRF is on a distinguished road
Hi everyone,
I am trying to simulate the non-premixed combustion of an industrial burner and I am having this message throughout the whole simulation. The number of cells affected vary from iteration to iteration but I canīt seem to get rid of it. After the simulation is "converged", there are around 30,000 cells affected out of 3M.
Iīve read through other threads with similar issues but in my case the simulation is converging to what appears to be a correct solution. The temperature contours look good but I am not completely confident due to these messages.
I have been monitoring the minimum temperature in the domain and it appears to be 2 K smaller than the temperatures I set at the air/fuel inlets (Tinlet = 291.15 K) while there is no heat taken from the domain. All boundary conditions are temperatures taken from a Berl combustor simulation. Can anyone help me with this?
Phanindra Raavi likes this.
MarkelRF is offline   Reply With Quote
enthalpy, minimum, temperature
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 08:42
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 15:52
