Particle Trajectory calculation
Old   February 17, 2001, 08:12
Default Particle Trajectory calculation
yueroo
Hi: I use FLUENT 5.5 's Discrete Phase Modeling to simulation particle and liquid flow in 180degree bend. This is laminer flow. I wnat to get accuracy prticle residence time. I found when I control the integration time step size from big time step size to small time step size , some particle will get unstable residence particle time . I put particle near wall ,I will get unstable residence particle time when integration time step size from big time step size to small time step size When I put particle far away wall , The result is stable. Can someone have some experience when you use Particle Trajectory calculation
THANKs!!
Old   February 17, 2001, 14:41
Default Re: Particle Trajectory calculation
K.T.
Do not use time step size for RTD. Instead, use the integration factor (?) in the same box. Use 30 - 40 to ensure that each cell is properly resolved with enough integration steps.
Old   July 13, 2009, 13:32
christian paul
cpaul is on a distinguished road
Hi all,
I need some help with VOF modeling in fluent. We have a 2D Horizontal micro channel that is 5e-05 meters in diameter and 7.5e-04 in length and we have the primary stage set to water and the secondary stage set to a type of oil found in the fluent database. We first ran a simple flow problem with just water. We saved those results and used them when we initiated the Volume of Fluid.
Here are our paramters.
Solver:
pressure based, 2D, absolute formulation, implicit formulation, unsteady time
Multiphase:
Explicit VOf scheme, implicit body force with two phases.
Material:
Water-liquid, Gas-oil liquid
operating conditions:
Left as is, we want to know if we should change this
Boundry condition:
Inlet velocity 0.001 m/s pressure is 0, should we change this?
Solve> controls
Equations are flow and volume fraction
Pressure velocity coupling- simple
pressure: Presto
Momentum: first order upwind
Volume fraction: geo-reconstruct
We would also like to know what the benifit of Patch is, and if it is necessary in our case.
The main problem we're having is that the bubbles are the same diameter as the channel, we would like to know if there is any way we can control the amount of oil that goes into the channel so our oil droplet would be roughly 10 microns.
Also if there is a way to measure the forces acting on the bubble.
thanks
cpaul is offline   Reply With Quote
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
how to output particle trajectory coordinate data steven CFX 0 July 13, 2006 17:49
Warning 097- AB Siemens 6 November 15, 2004 04:41
Particle Trajectory calculation when particle hit yueroo FLUENT 2 February 28, 2001 04:26
particle trajectory calculation ursenbacher Main CFD Forum 2 January 28, 1999 16:15
