Problem with Boundary Conditions using a journal file |
July 23, 2009, 11:41 |
I would like to simulate a flow around an airfoil with different angles of attack and different reynoldnumbers. The simulation works very well. I decided to use a journal file, so that the different simulations can run at night... The problem is: When I start Fluent (6.3.26) and run the journal file, it works. When I run it a second time without restarting fluent, the file is not able to change the boundary conditions (velocity inlet) to simulate the next angle of attack. Everything else works. I wanted to write one single journal file with the different conditions, but it does not work because of the problem I described above. My journal file is useless if I have to restart Fluent after every single simulation. My journal file is attached - I tried it with two different angles of attack.... It would be very nice if someone has an idea how to solve my problem! Thanks, Till |
July 25, 2009, 09:11 |
hi
reza
Rep Power: 16 |
hi.if you want to write a journal file and use it for many times ,i think you can do the following procedure:
write: solve monitors residual reset yes and then define new boundary conditions and ....... Last edited by vatovato; July 26, 2009 at 01:15. |
July 26, 2009, 10:17 |
Thanks for your help vatovato!
July 27, 2009, 08:31 |
reza
Rep Power: 16 |
your welcome
Display Modes | |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
boundary conditions for axisymmetric problem | eers | Main CFD Forum | 0 | June 19, 2009 14:52 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
