multiphase
Old   July 30, 2009, 04:43
Default multiphase
reza
vatovato is on a distinguished road
Hi everybody,
How we can see the interaction interface between two different phases in Fluent. For instance, we have two different sandy and water phases and we want to see the interface layer after running the program( I mean the amount of scour)?
vatovato is offline   Reply With Quote
Old   July 30, 2009, 17:02
Vidya
vidya is on a distinguished road
Have you created the interfaces in the first place? Also, what multiphase model are you using? VOF?
Vidya
vidya is offline   Reply With Quote
Old   August 2, 2009, 02:45
Default vidya
reza
Dear Vidya, I am trying to model the amount of scour at bridge piers, but I do not know which method I should apply and how? in you have any information about this subject please help me to run my problem, You see that at bridge piers we have at leasth two different phases , first is water phases and second is sandy phase and I want too see the interface layer between this seperate phases.scencerely yours.
Old   August 2, 2009, 09:56
Vidya
Dear Votavato,
I'd think that you also have to use the Volume of Fluid (VOF) multiphase model for your problem. I am also woking on a two-phase fluid flow situation where there are air and fluid phases. The fluid phase is actually a mixture of sand and slurry. I am using the VOF model for modeling the problem. You could probably try this one. This model also tracks the interfaces.
Let me know.
Vidya
Old   August 4, 2009, 05:09
reza
Dear Vidya,
thanks alot because of your caution, I saw an article about my problem the title of which is '' Numerical Investigation of Scale Effects on Local Scour around a bridge Pier'', in this paper the writer has used from Eulerian method, I am interested to learn it at the condition he has used in that model, unfortunately I couldn't find his Email address , if possible give me your email to send you the properties of my model an its situation.
scencerely yours,Amir
Old   August 5, 2009, 08:33
Vidya
Dear Amir,
My email address is vraja2003@gmail.com
multiphase multicomponent physics ckleanth CFX 3 June 4, 2009 20:15
Multiphase radiation in Ansys 10 problem Luk CFX 2 June 5, 2008 11:31
New to multiphase fluent simulation, any tutorials Camps FLUENT 0 September 9, 2006 11:41
Species Transport with multiphase flow Gopal Kasat FLUENT 3 July 12, 2005 18:59
Multiphase flow modeling Paul CFX 2 August 11, 2003 09:41
