Post-Processing...HELP!
Old   July 29, 2009, 09:17
Default Post-Processing...HELP!
qwerty753
qwerty753 is on a distinguished road
I wanna monitor the Temperature on the axis of a cylinder during the time of my simulation. (Unstady problem)
At the end, i would do a 3d graph in which x:flow direction; y:flow time; z:Temperature.
I have Tecplot too.
I would to know what and how parameteres i have to set in monitor, before i start the simulation.
Thanks.
qwerty753 is offline   Reply With Quote
Old   July 30, 2009, 03:03
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
*create line (surface/line/rake...)
*plot/x-y plot (enable write file)
here you may try to reach it with tui:
>plot
Once you have the right tui command and you are sure it works
you go under solver/execute... and you enter the above command (execute for each time step)
the filename you write should be someting like: blabla_%t.out (it will prevent fluent to overwrite all the files)
I don't have fluent anymore, so I cannot test it.
But this his how I would treat it.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
post processing for KIVA dirga Main CFD Forum 5 April 23, 2009 11:58
Question about post processing qtian OpenFOAM Post-Processing 0 July 24, 2007 13:44
Tecplot for CFX post processing pantangi goud CFX 2 August 24, 2005 17:42
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 12:59
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 21:51
