question about composition PDF transport model |
November 22, 2014, 21:25 |
Rep Power: 11 |
hello everyone,
recently i am simulating a jet burner with detailed chemical mechanism using PDF transport model. i have tried to use laminar finite rate-relax to chemical equilibrium as an initial solution, then using composition PDF transport to calculate the final result. but after the calculation, i found the velocity magnitude is much larger than the velocity i set, 10 times approximately. i also have tried using partially premixed model to calculate as the initial solution, finally the velocity still was wrong. please help me, so kind of you. thank you in advance! Last edited by lisa_china; November 23, 2014 at 09:12. |
November 23, 2014, 09:15 |
Rep Power: 11 |
please...
is there anyone who knows? |
November 23, 2014, 17:29 |
Rep Power: 13 |
There should be something wrong...it cannot be just a modeling error. Check you BC again (Mass flow, temperatures, pressures, etc).
November 23, 2014, 19:59 |
Rep Power: 11 |
hi Lucar,
i have checked my boundary conditions for several times, and they are right. would you prefer to help me for another question? should the particle velocity magnitude be the same as the velocity magnitude shown in the velocity contour? thank you very much and hope for your rely. |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Question about scalar transport | osimonsimon | OpenFOAM Running, Solving & CFD | 33 | August 21, 2020 10:45 |
question about Heat transfer between two phases with VOF model | sooroo3 | FLUENT | 0 | February 15, 2011 03:24 |
Eddy Viscosity Transport Model | Jade M | Main CFD Forum | 0 | April 21, 2010 14:17 |
DPM vs Species transport model | osh | FLUENT | 0 | August 19, 2005 22:15 |
