Prevent an iteration after the convergence
Hi everybody,
I'm new in fluent and I have a problem. I use fluent 6.3 in batch with a journal in input. I must stop the calculation after each iteration and then use the command iterate. I noticed that when the convergence is reached, the command "iterate" still works. Is there a option which avoid the iterations after the convergence ? Thank you for your help. |
It happens to me also. But just let it go, and it will stop soon!
Are you Sure ?
The convergence is reached after the iteration 9. Then I try the command "it 1" many times, and it still works after 100 iterations. |
