August 16, 2009, 06:48 |
Droplet Injection
Varun
Rep Power: 16 |
I have been trying to simulate spray using single orifice atomizer (and pressure swirl atomizer) injector models. Liquid Diesel droplets into ambient air.
I have a doubt regarding use of Species Transport. When I select a mixture in the species transport does it define the fluid domain as the mixture....?? The Particle Type = Droplet is disabled in the injector definition window. I am using k-epsilon turbulance model and also DPM... I noticed that Droplet option gets enabled when i enable Species Transport. But i'm unable to understand how to get sort out the issue. I would appreciate it if any one could tell me how to overcome this, or to use droplet model is it compulsary to use Species Transport?? and if yes how do i retain the domain to be ambient air?? |
August 18, 2009, 13:41 |
Allan Walsh
Rep Power: 17 |
What are you trying to do? If you want to see how the vaporized diesel is dispersed, then you need to have an air-diesel mixture. If you only care about the condensed phase (i.e. liquid diesel drops), then the gas could be something else.
Probably, you want to choose air-diesel vapor from the Fluent data base for the fluid (i.e. gas) mixture. Then, chose diesel as the material for the particles from the material set up panel. Good Luck. |
August 18, 2009, 13:47 |
Varun
Rep Power: 16 |
Yes I'm looking to injected liquid droplets and have set up the injector to do so....
Nope i'm not looking for vapourization... i'm trying to study droplet distribution... |
August 19, 2009, 12:24 |
Allan Walsh
Rep Power: 17 |
Sorry, I can't follow what you are trying to do or what your actual problem is.
August 19, 2009, 12:46 |
Varun
Rep Power: 16 |
I've managed to sort that particular problem out.... Thank you...
But i've got a couple more doubts..... 1. Pressure Swirl Atomizer in FLUENT does not seem to have an option to specify swirl component. I dont see any swirl in the spray produced by it. Is there any way that the swirl velocity component can be input....? In simple words - How do i get swirl...??? 2. Under advanced DPM Injections where the number of tracked particles, escaped....etc are listed out what does particles shed & incomplete mean...?? Please help.... Regards Varun |
droplet falling - VOF | bohis | FLUENT | 1 | July 10, 2013 04:28 |
Help!!!! - Droplet Injection | varunrajendra | FLUENT | 0 | August 15, 2009 11:26 |
DPM,define the instantaneous droplet injection vel | Stan | FLUENT | 0 | July 12, 2008 07:32 |
Help with droplet injection!! | Maria | CFX | 1 | August 16, 2007 04:53 |
HELP:UNSTEADY DROPLET COMBUSTION | James Willie | FLUENT | 0 | August 5, 2005 17:42 |
