conduction between fluid and solid
Old   September 1, 2009, 12:04
Default conduction between fluid and solid
MK
takin is on a distinguished road
I want to simulate a geometry like this:
T_o
solid
--------- <-interface
Fluid
T_i
I have already generated the geometry and mesh for two zones solid and fluid.
I do'nt know what kind of thermal boundary condition should be applied at wall defined as interface.
takin is offline   Reply With Quote
Old   September 1, 2009, 13:14
Silvia
Manucia is on a distinguished road
At the interface you should have two faces, (one and its shadow)
Both must be set as Thermal coupled condition
hope it helps
Manucia is offline   Reply With Quote
Old   September 2, 2009, 03:28
Default help!
MK
hope it helps
thank you, but How can I set the"Thermal coupled condition"?
Old   September 2, 2009, 11:03
Silvia
Define/Boundary conditions/open the thermal panel/ under thermal conditions set "coupled"
boundary condition, conduction, conjugate heat transfer
How To Convert Fluid wall in Solid Wall Boundary Condition RGN FLUENT 4 March 31, 2009 04:43
Fluid - Solid Domain Interface Daniel CFX 6 February 15, 2009 18:09
coupling solid and fluid cells?? kcg Siemens 4 March 13, 2007 09:39
Modeling of solid domains in fluent, no fluid flow Satish Perivilli FLUENT 2 December 1, 2005 11:41
Heat conduction through solid rib in periodic duct Dieter Fauconnier FLUENT 0 October 7, 2004 08:22
