If my solution is converged ?
2 Attachment(s)
I want to use the time-dependant solver to get the steady state. And I also monitor some important parameters, such as temperature, vof...
After some iterations, I found these parameters almost do not change, but the residuals remains at a high value(10-2) and goes flat. I wonder if I my problem is converged ? The residula and monitor look like this > Attachment 1011Attachment 1012 |
Residuals becoming flat may indicate:
1. Your solution has converged, or 2. This is the minimum residual possible with your current grid. For further reduction in residuals, you may have to refine or adapt the grid. |
Yeah, I agree with srjp. You're going to need to refine your grid. I would recommend plotting contours of mass imbalance (since your continuity residuals didn't converge) and refining where they are high.
-sean |
you both wrong.
this is transient solution and if one decrease the time step the residuals will decrease too. you execute 1 ineration on 1 time step? |
the continuity residuals are too high.
reduce your time step |
Sorry, I thought it was steady state simulation.
May be after frustration of seeing so many flat residuals !!! Agree with mAx on the timestep reduction. |
ditto.
-sean |
Yes, 1 interation on 1 time step at beginning, because I want save computation time. And then I increase the interations each time step, and the residuals also remain flat.
forget 1 iteration per time step
try the default settings, eg: 20 iterations per time step I would also recommend you to start your unsteady computation from a well converged steady solution |
Most likely you are using a too big time-step. The time in your pictures is 2.4e4. Imagine if time step=1e-6, how many steps it will be....
Character of success iteration???
Hello!!!
I'm a new user in FLUENT. I've read your Post. I wanna know what is the indication that we have success iteration?? I've thought that FLAT graph on the Residual graph is the indication!!! Am I wrong???:rolleyes: |
I think when the we get converged solution, the residual will go flat. But at the same time, the residual should fulfill the criterion, such as 10e-4,10e-5...
Flat or not it is no matter. If iteration converged then it is. I think so.
Regards. |
Is there an equation to prove it?? just to know how much convergence value!!!
there is navier-stokes equation.
and http://en.wikipedia.org/wiki/Residua...rical_analysis) regards. |
