September 12, 2009, 16:46 |
Defining Regions and Patching
I am attempting to simulate laminar two-phase flow in a triangular capillary using the computational fluid dynamics code of FLUENT --- it is intended to be an immiscible flow in which the wetting phase displaces the non-wetting phase in a piston-like transport process.
According to observations, the meniscus is supposed to be a cup-like (spherical) interface separating the two phases. The problem I have is that I do not see the two phases whenever I define regions and patch them; I only see one phase in the entire length of the capillary. I will appreciate every good suggestions. Note: It is a microscale VOF type flow! |
September 14, 2009, 01:21 |
Maxime Perelli
Rep Power: 41 |
if you defined the 2 regions, then you go to initialize, and after (in this order) you set the vof-region with patch.
In memory of my friend Hervé: CFD engineer & freerider |
VOF Patching fluids at an angle? | Brian | FLUENT | 0 | October 26, 2005 20:58 |
