September 10, 2009, 08:59 |
2 phase flow help
Sherif
Rep Power: 17 |
hi all,
i am doing my bachelor project is simulation of 2 phase flow (liquid gas) in pipeline and i need some help please my case is that i have a pipe line immersed in water and opened from the bottom part and the side, and then air enters from the side and pushes the water up so it acts as air lift pump boudary counditions bottom is inlet vent and the side is pressure inlet for air whenever i enter my boundary conditions i dont get results i dont know why my pressure inlet is 80,000 pascal and at the inlet vent the initial pressure is 40,000 pascal. attached is what i get thank you for your help |
September 11, 2009, 03:30 |
Svetlin Filipov
Rep Power: 17 |
I do not understand why the bottom of the pipe is not a wall for example, and the second why you use inlet vent as a BC?!?!?! Just fill the pipe with water, tell if the top of the pipe is open and set air inlet as mass or velocity inlet...
September 11, 2009, 10:06 |
JP
Rep Power: 18 |
You can try pressure inlet condition for water, and may be mass flow/velocity inlet for air.
September 13, 2009, 04:29 |
Sherif
Rep Power: 17 |
thank you for your reply...
i am not very familiar with fluent so my questions would seem easy for Philipov 1- How to tell fluent that pipeline is filled with water or it is set automatically 2- the top is defined as Pressure outlet for Srjp i will try your Suggestion Thank you |
September 13, 2009, 10:40 |
Svetlin Filipov
Rep Power: 17 |
After initialization of the calculation (just before to pres the iterate button) go to "Patch..." command and tel that all the domain is filled with water (volume fraction=1)
Display Modes | |
Two Phase flow modeling in commercial softwares | Sandeep Rane | Main CFD Forum | 9 | February 17, 2010 07:23 |
Validation for laminar Disperse phase flow | shashwat | Main CFD Forum | 0 | April 4, 2008 03:20 |
how 2 freeze 1 phase flow field & start lagrangian | KK | CFX | 5 | February 14, 2008 17:48 |
Two phase flow in porous media | Madhavi Krishnan | FLUENT | 3 | June 6, 2005 06:52 |
2 phase flow equation in 1D | Nicolas | Main CFD Forum | 0 | December 13, 2003 15:19 |
