September 15, 2009, 11:40 |
physical appearance !!!!
pipin
In a model of a nozzle i've to set up the density of my gas to constant in the first iteration... It's the first time, i have to do this, before, i set up 0.4 for the pressure urf and 0.3 for momentum and finally i turned off the energy but with real gas model!!!! Could you explain me, why sometimes this problem appears. Thanks |
September 15, 2009, 11:42 |
pipin
I forgot:
After few iteration with constant density, the model converge even when i change for ideal gas. Thanks |
[Gmsh] Version 20 of the bmshb file format to FOAM converter | 7islands | OpenFOAM Meshing & Mesh Conversion | 36 | February 9, 2019 22:47 |
Viscous resistance coefficient in physical v-model | AL | FLUENT | 0 | December 15, 2008 14:52 |
OpenFOAM 13 Intel quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 13 | February 5, 2008 05:26 |
OpenFOAM 13 AMD quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 1 | November 10, 2007 23:23 |
