Natural Convection
Old   December 5, 2007, 04:10
Default Natural Convection
racheal
Hi FLUENT users.
I'm working on a natural convection problem, ie a solar chimney. air will be drawn from the bottom of my system upwards. Due to temperature difference, air will flow through the chimney. I have problems with setting up the parameters in FLUENT. the minimum temperature involved is about 25C whereas teh highest temperature is 80C for this system.
For operating conditions: I have set gravity to be -9.81m/s2, correct? For Boussinesq parameters, what is the operating temperature that I have to set or shall I keep the default value? Do I need to specify variable-density parameters?
For Material (air): I use Boussinesq method to specify density, but do I need to key in a value (by default FLUENT changed to 0)? If so, what is the value? what other parameters that I have to set in the material panel?
I have used PRESTO! for discretization method, is that good?
What else do I have to consider?
Sorry for such a long question, hope to see your reply, thanks!
Old   December 5, 2007, 12:07
Default Re: Natural Convection
Vaibhav
Hi Racheal If you are using Boussinesq approximation, specify density at one ref temp which might be room temp or 25C in your case.
Specify the volumetric coefficient of expansion for air.
Specify density in material panel box (No need to specify variable density parameters)
Please refer the fluent tutorial on natural convection for more details.
Vaibhav
Old   December 5, 2007, 19:17
racheal
hi!
I have actually went through the tutorial 'modeling radiation and natural convection', but I'm not sure why those values were selected, eg the '1000 kg/m3' for density and '1e-5 K-1' for thermal expansion coefficient. I wonder how these values are calculated. Hope to see your reply, thanks!
Old   December 17, 2007, 14:07
albo30
sent to me your file" cas and data" i try to help you
Old   December 18, 2007, 02:08
Rami
Racheal,
Since you deal with air at nearly standard conditions, the ideal gas model may be a good approximation for estimating the thermal expansion coefficient. With this model, the volumetric thermal expansion coefficient =1/T (T in absolute units, e.g., K).
I hope this helps, Rami
Old   September 26, 2009, 23:42
Smile hello,please help me
zhangmin
lucifer is on a distinguished road
I read your post in the forum,and I have the same questions with you.since the post is a long time ,I think you must have solve the problems,please please help me!
For operating conditions: how can I set the gravity? For Boussinesq parameters, what is the operating temperature that I have to set or shall I keep the default value? Do I need to specify variable-density arameters?
Where can I find the air's thermal expansion coefficient and absorption coefficient?
I really hope to see your reply, thanks a lot!
please help me !
lucifer is offline   Reply With Quote
Old   September 26, 2009, 23:52
zhangmin
Originally Posted by racheal
;147087
Hi FLUENT users.
please help me !
Old   September 27, 2009, 06:17
Akour
ak6g08 is on a distinguished road
hello,
a lot of people have been asking about what parameters to use in a natural convection problem. This is exactly why in cfd you should always try to work using non-dimensional numbers, that way you can characterise your problem with any physical properties you use. For natural convection the Rayleigh number is what you are interested in, depending on what sort of convection you want to see you can choose this number accordingly, along with th Reynolds number which will define the level of turbulence.
so to answer the question, type rayleigh number in to google and look at how it is calculated. Also, remember that the the boussinesq approximation is NOT always the way to go, i recommend you look up the limitations of using the boussinesq approximation, e.g. for large temperature gradients and specific thermal expansion coefficients the boussinesq approximation is not good. Instead of the boussinesq approximation you could calculate density on each iteration using a 1st order polynomial = rho(T)=rho(0) + beta*DT sort of thing
hope that helped a bit.
good luck
akour
ak6g08 is offline   Reply With Quote
Old   September 28, 2009, 08:41
Default re: natural convection
avuttide is on a distinguished road
Hi, About the problem of the parameter that you set in fluent in boussinnesq appox. I think that everything depends on the reference temperature that you want to use; that means, density change with temperature and so the thermal expansion.... once u decide the bulk/refernce temperature, this will be the the operating temperature in the operating condition pannel....
for this temperature check in the web the density, and the thermal expansion parameter and put the value in the material pannel.
using density-boussinsq model, means using a density constant value but you have to indicate how... that means that is you reference temperature value is the default Fluent reference temperature, density will have the default density reference value.
For the other parameter try to use the default parameter of the fluid that you are using.
however on the Udf manual there is a strategy for natural convenction
and I have find very very helpful; they suggest both PRESTO! and also body force weighted.
hope it helps
avuttide is offline   Reply With Quote
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
Natural Convection with heat generation krishnachandranr Main CFD Forum 0 July 28, 2009 04:22
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 04:58
natural convection at high Rayleigh mauricio FLUENT 2 February 23, 2005 19:43
Mixing By Natural Convection Processes Greg Perkins FLUENT 0 February 12, 2003 18:40
