help in fixing inflow
1 Attachment(s)
hii every one i have a problem in fixing my inflow for a four inlet micro channel. wat i need to do is allow 2 fluids flow through two inlets then later two other fluids flow through two other inlets. and finally i need to see the mixing of all the four fluids. the figure shows the actual model which i spoke.
thank you |
