October 28, 2009, 10:40 |
Surface Pressure Osciallation
Matt
Rep Power: 16 |
I am simulating flow around a wind turbine blade section. The Reynolds number is quite high (3e6) and as such i am using a turbulent model. I am none too familiar with turbulence theories but have been using the k-omega with a turbulent kinetic energy calculated via k=(3/2)(Ti*U)^2 and specific dissipation from k/w<=Re .
I am searching for a steady state solution to compare with some experimental results. The simulation runs and converges fine and lift data is roughly 5% low compared to the experimental data. Where i'm having issues is on the surface pressure distributions. I'm getting some checker boarding on the top leading edge of the airfoil and i can't figure out why. Below is an element plot of the pressure contour and i have circle the checker boarding. Here is a picture of my grid. I built the grid in such a way that for the first 1% of chord away from the airfoil i used a structured grid and then progressed to an unstructured grid. Also a closeup of the mesh near the airfoil. I am using a Y+ of about 14 here. I have tried from 20 down to 4 with the same oscillating surface pressure results. Here is a plot of the surface pressure compared to the experimental data i have. You can see the squigles at the top leading edge of the airfoil. Anyone have any ideas on how to get rid of these. I have read about the Rhie and Chow technique of discretization and i and assume fluent can use this. I must be using the wrong solver or have a parameter set wrong. Also this is an incompressible simulation. |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 10:08 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Pressure enigma. | Sara | Main CFD Forum | 22 | July 30, 2009 04:46 |
How to get the pressure force on a surface? | Jimmy | Siemens | 5 | January 25, 2008 05:54 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
