Using Multiphase
Old   October 28, 2009, 12:01
Default Using Multiphase
Boris Styward
Styward is on a distinguished road
I have a system, and the system is like this
I have a reservoir which is filled by water with head = 2 or 3 metres, the reservoir is connected to the pipe, and then the pipe is connected to a ventury, and at the end of the pipe, it is directly connected to the atmosphere,
in the ventury , the pressure in the center of the smallest area of the pipe is lower than pressure of the atmosphere, so if we make a hole/connecting pipe that makes it directly connected to the air, so air is moving in to the ventury.
the system can be called a hydro ventury system,
the purpose of my project is to make a proper wind turbine in duct that get the power from this hydro ventury system,
first, i want to simulate the system, to know how fast that the wind blow through the duct that connected to the ventury, and i don't know how to do it with FLUENT, because my friend told me that it have to use a multiphase model, and i don't understand how to use multiphase.
if any of you could help my problem, and told me how to use multiphase and the boundary condition that i must use in the system, it will be a pleasure for me
Thank you!!
Styward is offline   Reply With Quote
Old   October 30, 2009, 08:14
Thumbs up try it
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
You can see it in this web
http://www.fluent.com/software/sf_me...orial_wave.htm
hope it helps
teguhtf
teguhtf is offline   Reply With Quote
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 05:29
multiphase multicomponent physics ckleanth CFX 3 June 4, 2009 20:15
low concentration multiphase zwdi FLUENT 4 June 1, 2009 17:10
Multiphase flow modeling Paul CFX 2 August 11, 2003 09:41
Why and where should multiphase be used? Seo, Hyeoncheol Main CFD Forum 2 June 18, 2002 10:52
