Fluent Parallel Programing using Windows HPC 2008 |
November 9, 2009, 00:55 |
Santosh
Hii,
I am building a 4 node compute cluster for running Fluent using the Windows HPC 2008 software. I am absolutely new to this and had few questions. 1. In the Fluent Launcher, it asks for the Machine List. What is the format of that? 2. I have created a head node, and a compute node (checking for 2 nodes now). When I start Fluent Launcher and input the parameters and try Launching it, no connection takes place. It does show that it is receiving data from the other computer in the Networking box, but it is not getting reflected in Fluent. Please help me with this, I will come up with more questions once these steps are clear. Thanks a lot Santosh |
November 11, 2009, 09:20 |
Adward
first you must sure that these computers can visit each other in network neiborhood
November 12, 2009, 03:35 |
tomtom@MS
Have you looked at the Fluent guide for HPCS 2008 ? "Configuring and Launching FLUENT 12.0.16 on Microsoft HPC 2008" http://www.fluentusers.com/support/i...nfaq/hpc12.htm Did you tryed to passed the diagnostics from HPC Server ? By the way, with the fluent launcher you shouldn't have to give him a node list, the HPCS scheduler will provide that to Fluent. Best regards, Tom |
November 13, 2009, 07:51 |
Santosh
No, I do not have that. My institute did not allow access to that website, maybe I will ask them.
If you have a copy, could you please send me. Thanks a lot |
November 18, 2009, 06:03 |
Santosh
Bump.. Please help.
December 9, 2009, 13:20 |
#6 | |
Santosh
Please help.
February 25, 2010, 09:36 |
Ansys
Basharat
Hey... tell me your problem again. i think I can resolve it....
Martin )) |
February 25, 2010, 09:42 |
Santosh
Thanks for posting Martin. But I could solve it. Now set up a 4 node private cluster for Fluent simulations..
February 25, 2010, 13:59 |
Basharat
ok Good ))... Good luck man. I have worked on linux and windows both of them.
February 25, 2010, 14:10 |
Santosh
Martin,
I had one doubt though. I had to install Fluent on all the 4 nodes, as the MPICH2 package was needed. Is there any other way to do that without installing Fluent in all the machines? Thank you. |
February 25, 2010, 14:14 |
#11 |
Basharat
Dear !
as MPICH2 (Message passing interface)is the best network protocol or software like for good communication and maximum processor performance as well as memory. tell me in detail you need to install mpich2 or what else you want? |
February 25, 2010, 14:20 |
#12 |
Santosh
Martin,
Sorry, you didn't get my question. In order to run Fluent in parallel, I am using mpich2 as the MPI Architecture. Now, the Fluent in installed on my Head Node, and all the compute nodes are connected to the Head Node. Now I am running Parallel-Fluent using the Fluent Launcher. While Launching, it gives an error, MPICH2 not found on the compute nodes. Hence, I install Fluent in each one of them, and run it again, and now it works. So, my question is, is it possible to run Parallel -Fluent without installing Fluent in all the compute nodes? If yes, then where can I find the MPICH2 package for the particular Fluent version. Thank you |
February 25, 2010, 14:29 |
#13 |
Basharat
yeah. you can!
share the head node fluent folder and check if it is accessing from all nodes. then in this share folder of fluent find the multiport folder and see there mpi folder. there is a file of smpd and other files also, copy all files in your system32 or syswow64 (in case of 64 bit) folder. go to command line and install smpd service by typing smpd -install you have to install this service in all your nodes and there is also a file of cluster manager where you can see all your nodes and head node are online highlighted by green line. so have you got it? |
February 25, 2010, 14:32 |
#14 |
Santosh
Wow, thanks a lot. Got it perfectly well. I had installed smpd in all the other systems manually after Fluent installation. This idea din't strike me earlier.
Thanks again.. |
February 25, 2010, 14:37 |
#15 |
Basharat
ook... good luck friend. tell you have you ever worked on ansys 12 whether on linux or windows HPC ?
February 25, 2010, 14:38 |
#16 |
Santosh
No never. I am working on Fluent 6.3 version.
August 14, 2010, 07:47 |
parallel fluent
#17 |
Can any one tell me how to run parallel fluent on 16 processors 2 node cluster using mpi command. I have 8 processors on each node. thanks frnds |
August 14, 2010, 08:13 |
#18 |
Basharat
first tell me your scenario ...
I mean.. which version of Ansys you are using and what you want to do exactly ?
Rgds Martin |
May 23, 2011, 03:37 |
#19 |
Mohammad
hi all,
I had a question which I cant find any answer in fluent userguide or other helps. I want to have fluent in parallel mode on some nodes(and each node has some cpu cores) but nodes dont have same operating system. some of them have linux amd64 and some have win64. I dont know if I can spawn nodes or not; and if I can, how should be the machine list; should linux systems and windows systems have same username and password to do that or not? thsnks for any help |
February 16, 2013, 17:54 |
#20 | |
I am running Fluent 14 on 2 nodes using Windows 7. I first did a network of these 2 computers; then I set up Fluent and Intel MPI. The Fluent directory is shared in the network as the working directory of Fluent. I am launching Fluent with 8 processes and it does not hangs when opening. Now it is iterating for the solution but it's taking too long between iterations. I mean, it's kind of pausing after each iteration and it'll take too long to reach convergence if I don't improve this issue. I assume this is due the communication between pcs is delayed or there is a kind of bottleneck in the network. I am please asking you for an advice in this. Thanks in advance, César |
machine list, parallel computing, windows hpc 2008 |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
CFX in Windows HPC 2008 | Srikanth | CFX | 5 | February 15, 2010 03:42 |
Fluent parallel license problem | brothershuai | Main CFD Forum | 0 | July 1, 2009 15:41 |
Any Luck with 64-bit FLUENT on 64-bit Windows? | Dylan | FLUENT | 4 | October 17, 2007 11:14 |
Windows vistar v.s. Fluent Parallel? | Susan YU | FLUENT | 3 | August 15, 2007 23:58 |
